1 - 6 of 6 Posts
Although originally posted on FB, I will post here too as it disappear a little too quickly on FB.
What you see is a little experiment with a different type of motor-mount/chassis 3D printing method.
I made available on my Thingiverse: Scalextric Ford Sierra Chassis by Johnny_s_Workshop
Instructions are available in the link above.
Picture below: from bottom left to right is the original chassis, PCR chassis and the actual result.
Above are previous iterations.
Automotive tire Toy Vehicle Motor vehicle Automotive design
As it comes out, if you attempt this print:
leave it to cool down before trying to unbind the motor-mount.
Give it a gentle twist until you hear a 'click' from each holding point.
Then you can push the motor-mount back and forth to get it loose.
Motor vehicle Circuit component Auto part Monochrome photography Engineering
Comparison between other chassis:
Tire Automotive tire Hood Wheel Wood
Tire Automotive tire Audio equipment Office equipment Wheel
Automotive tire Tire Motor vehicle Wood Wheel
Watch Circuit component Gauge Clock Gadget
Note how the car height is lower than the original and wheels rest inside body.
I only had a spare set of 17 mm rear hubs to experiment. I recommend using 16 mm rear hubs instead:
Interior had to be cleared of all posts and weld joints:
Bumper Auto part Engineering Automotive exterior Machine
This is most definitely not a competitive setting. Just an experiment.
Rectangle Lego Auto part Font Building sets
Very nice. Any specific reason why you are mounting the motor in that orientation (with pinion going on the plastic end side)?
Thanks, yes: it's so it can be assembled using the original Scalextric S-Can motor (Slot it S-Can motor-mounts are also oriented that way).
ParrotGod
I see...nice to reuse parts.
I have to admit I do not know much about 3dp, but if I follow what MrFlippant is saying, the pod is a separate piece....if this is the case, you could have two versions which would take the motor in the other orientation (I think is called can end???) which for some is a better choice.
Done! I made a tweak and available.. It's the Chassis B with reversed can
1 - 6 of 6 Posts
