1 - 4 of 4 Posts
Just doing some more testing and I noticed that the fuel leds stay lit for races that are non fuel races. Is that normal behavior ?
I rebooted the cpu and rebooted the LED power supply and then created a fresh race without fuel but then when you start the race, "fuel level" leds for each lane come on. I assume the track setup tells it to turn on and it that it does not know to turn off if there is no fuel used in the race option?
You need to change the skin (xaml) file for non-fuel races or change the track configuration.
Are you talking about the rgb leds? It's likely because in non-fuel races the fuel level is always viewed as 100%, but for the purposes of those Leds, in a non-fuel race they should be told there is 0 fuel so they turn off...
yeah the LED's I use stay on. I am going to try a few more things and see if I can get it sorted out. I just wanted to know if you had it set to turn off when not in use or just stay on.
1 - 4 of 4 Posts
