QUOTE (Lloyd.L @ 29 May 2012, 14:00)
<{POST_SNAPBACK}>Hi, just one thing, having seen your new photos, make sure you have access to the track inside the tunnels, if not you can be sure that if you have any track problems, that's where they will be! I know this to my cost, my tunnel now has a removable side panel!
Regards, Lloyd.
The tunnel section in the mountains has had the track cleaned and the park section one has access via the side,i have been running the blue suburu and it runs perfectly even with paint/plaster/pva glue on the track but 3 power taps help.
there are only 2 corners that have to be taken with caution but the x overs add to the fun.
on the carrera controllers i have enabled the turbo boost button to be used in any throttle position even a standing start so makes for interesting races.
