1 - 5 of 5 Posts
Try Pendle's
If you mean a 1960s unit, your best bet would be Phil Smith at www.scaleslotcarspares.com (in England).
The big block-shaped MRRC guides may be scarce nowadays but Phil has a vast store of parts. Much of it is not listed on the website but you can contact him through it and ask.
The guides for the later 1960s Airfix-MRRC units are completely different and more common. If it's one of them that you need, specify which one - probably Clubman Special but possibly ballrace chassis.
Rob J
· Phil Smith
As Rob says depends on which one you want, a picture of the unit you have would be helpful as there are several different types, if it is a Ballrace unit then these are unobtanium, I have the others including 4WD (these are expensive
QUOTE there,s half a dozen on ebay right now
any chance of pointing to where these are?
1 - 5 of 5 Posts
