1 - 4 of 4 Posts
Just a little something that I have tried out...... I have been having a frustrating time with my TSRF chassis on the inner most turns on the Scalex tracks....
The turns are so tight I loose contact with the guide pin and braid on the chassis.. So I worked out a way to put a Slot-it guide flag on the chassis... Simple and easy to do......
If some of you are having the same problems this might work for you.....
http://jbriggsk9.tripod.com/chrisbriggsslotcarpage/id39.html
chris...
Thanks guys
As I dont have a plastic track set up right now I will not be able to test the chassis until Friday..... But I see no reason why it shouldn't work just fine.... I will post a update on Sat.
Chris......
1 - 4 of 4 Posts
