1 - 9 of 9 Posts
Can any one help?
Just recently the screen has been showing multiple cars on track when only one is running and Murrey is constantly telling me I've done an absolutely incredible lap when I am just part way around the lap.
Something is making the system register all the cars and the lap counter to count cars constantly.
I have a PB pro, simple h running SSDC.
Its only just started messing about recently and it is inconsistant. Sometimes it works fine.
My powerbase has been seperated from the track and I have a spare one so have tried using that and the problem still occurs.
Any suggestions would be gratefully received.
Trev
My first thought is wrong serial port. If you're using a USB based port, and something changed with windows, it could have reassigned the port numbers.
The other idea is that something is injecting interference into the cables. Try moving the Aux cable away from other wires or electronics.
I too have had this problem previously and never got to the bottom of it. Most of the time now I use an APB and DisplayPro but it would be good to know why this is happening.
Do you have any bright lights that could be triggering the sensors?
Circuit Owner
Is the problem that you are using v5.x with pbpro? I didn't think v5 supported the old power base. Or am I out of date?
Just a note. A car shorted and the result was another car on the screen. When race finished a new race started with no extra cat. So while not exactly the same it does show bad conectivity can produce "gosts in the machine". ;-)
1 - 9 of 9 Posts
