1 - 17 of 17 Posts
Tony Condon
The lime green ferraris were run by BRP which was part owned by alfred moss ,stirlings dad ,the tartan was from the crauford clan which was stirling moss,s mum, Aileens' maiden name
not sure if that helps or not but there is a crawford tartan shown in that list of tartans which looks about right
Cheers tony
Phil Smith
I did the decals for this car a couple of years ago and used this tartan
Now I remember doing a lot of searching for the correct tartan but cannot remember if I ever found it or just used something that looked right!
also some Lola GT on the sheet.
*** Leo A Capaldi ***
Is that car not an Innes Ireland one ? Innes's family were descended from the McGregor clan so it would likely be McGregor tartan (as Martin says above but for different reaons).
The stirling Moss tartan connection was the seating material in his Mercedes again as Martin says via his mother.
Kind regards, Leo
Alfie Noakes
And you'll need something to rest it on while the tartan paint dries, so remember to ask them for a long stand.
Richard
Discussion Starter · #13 ·
What a can of worms this turned out to be!!!! There are only a zillion tartans and about a million in any one catagory : )) Thanks one and all for the help--if nothing else I found the Stewart Tartan. I especially like the checkered paint idea--could youse that to simply do the stripe around Innes Ireland's helmet.
Thanks again
Howard
QUOTE scaleslotcars Posted Today, 10:50 AM
Hi Phil,
Surely that's a Royal Stewart tartan you've used.
This is the tartan of the royal family and all of the Queen's subjects are allowed to wear this tartan - even the English ones!
I don't know for sure which tartan BRP actually used or even if it was always the same one but I am sure it wasn't a Royal Stewart.
Cheers.
Mick.
Phil Smith
QUOTE Surely that's a Royal Stewart tartan you've used.
I did say I wasn't sure if it was the right one, as I said in my post.
QUOTE Now I remember doing a lot of searching for the correct tartan but cannot remember if I ever found it or just used something that looked right!
So I guess I must have used one that looked about right.
QUOTE If you got a better picture of the car you could probably just copy the image of the tartan, by the time you print the decal at 1/32 it should look OK.
That's what I did, but took an image of the tartan from one of the many sites showing them, looked ok in 1/32 but of course for a proper job you should redraw it in CorelDraw (or what ever drawing program you use)
If you do a search for MacGregor tartans you do get quite a few and some are quite different to each other, but this seems a typical one.
1 - 17 of 17 Posts
