1 - 9 of 9 Posts
Hi everyone,
As part of my ongoing project to build something to beat the obligatory NSR Moslers in our Club no magnet open class, I've formulated a plan for the next chassis.
Having started with this slightly ambitious brass chassied Nissan GT-R, I moved onto a more simple brass pan Mercedes CLK GTR, then a Lexus SC430 JGTC with a stressed member Slot.It anglewinder motor pod.
Each iteration got quicker, but still not quick enough! I've come to the conclusion that the brass is too heavy and that the bodyshells have centres of gravity that are too high.
Therefore, the next chassis will be made from carbon fibre sheet and the bodyshell will be a low slung LMP or GT1 type with a long wheelbase and wide track.
I have an AvantSlot Audi R10 body which fulfils these criteria but is a little restrictive in terms of motor movement etc.
Therefore, my question is could anyone recommend an alternative bodyshell that is readily available? I've seen a Ninco Acura on Pendle which could be appropriate. The Slot.It Mazda also appeals.
Any answers would be greatly appreciated.
Dave
Are vac formed body shells allowed in you club's open class?
There are hundreds of types readily available.
Vac formed body shells are so much lighter than injection moulded bodies you'll have no trouble in getting a much lower c of g.
I think many of the slot.it cars are available now as body kits and also some Scaleautos are too (usually listed under 'spares'), and even some Ninco 'lightened' ones. If you're allowed vacforms, that's the route to follow, as 300SLR recommends.
Vac forms aren't allowed in the class. I think what Dave is after is something with a high enough rear deck to clear a side or angle winder. Most aerodynamic LMP cars have a low rear deck, indeed some models have to have a hump to clear the contrate gear when in inline configuration. A front engine Panoz has quite a high rear if you don't mind cutting the interior detail. However in my opinion Dave is quite quick enough with what he's already got.
Allan
· Giacomo
BTW maybe you can save weight not using the slot.it pod since you give enough flexibility to the fron and rear train already and you skip some (heavy) screws
With your skills it should not be difficult to scratch build a light motor bracket.
If I compare the NSR Mosler chassis with a brass made one I found that it has a great deal of flexibility while the brass ones are more rigid.
Maybe it is enough to reduce even more the thikness of the brass sheet and/or use thin music wire.
Please this is just speculation since I am not lucky like you guys in UK with hundreds of clubs
. Here I cannot test my scratch built in a club right now, so I am very interested in your opinions.
JamieG
· Phil Clayton
The AvantSlot Audi will give the low CofG and is light in weight but as you say clearance could be a problem. You could try a Slot.it Flat6 motor or one of the more powerful slimline motors from Scaleauto (not seen one use in an AW config tho') to fit.
An alternative bodyshell would be any of Slot.it's GroupC range, but use a lightweight interior.
Looking forward to seeing how this progresses.
There are a few LMP bodies which allow sidewinders or anglewinders. I prefer the NINCO BMW V12 LMP for that.
In the inline field one of the very well handling bodies still is the Pro Slot Toyota GT1.
Roland
Thanks for the responses everyone!
@300SLR, no, I'm afraid vac-forms aren't allowed
@aerodynamic, I've been looking at the Slot.It bodykits and do quite fancy the look of the Mazda. It'd be perfect in terms of the higher rear deck as well as the low overall C of G.
If anyone has a Slot.It Mazda, it'd be a great help if you could measure the wheelbase and track for me.
I also saw the ScaleAuto Radical body kit. Again, if anyone could help me with these dimensions, it'd be much appreciated.
Hi Al. I thought about the Panoz, but disregarded it on account of the wheelbase, which if I remember correctly, isn't really long enough. And cheers, but I really want to beat the Moslers! Although saying that, me, Warby and Phil stayed on for a test session last week and set some pretty good times. I got down to 6.7ish with the HRS Porsche. Then Warby did a 6.528! Definitely cheating! Haha.
@JamieG, the Nissan would have been my first choice for a Slot.It body kit, but unfortunately the kits aren't available on their own
And thank you for your kind comments. Unfortunately, the performance never really matched the level of over-engineering lol.
With regards to the motor mount, although I could attempt a scratchbuilt piece, the ease at which everything is lined up when using the Slot.It item really appeals.
As for chassis stiffness, my driving style suits a stiffer main chassis with a motor mount that is free to rock, giving a suspension effect. Therefore, carbon fibre should be perfect because it's stiff and very light.
@ThatCorvetteGuy, I hadn't thought of the Flat6. That's definitely an avenue for me to explore
. Cheers. I prefer the inline configuration anyway so hopefully it should fit. The wheelbase of the AvantSlot Audi really appeals. It's longer even than the ProSlot GT One I used to campaign in this class.
@Schackel, I've had both of those bodies in the past and loved both of them. I still have the ProSlot Toyota, but it's in such a state of disrepair, I thought something new might be better
The Ninco BMW LMP/LMR would be perfect, but I have no idea where I could get hold of one. If anyone has one they might consider parting with, please PM me!
Thanks again guys. I'll post a diagram of what I'm thinking about later.
Dave
1 - 9 of 9 Posts
