1 - 9 of 9 Posts
Hi, I've started researching the following cars with a view to attempt to scratch build them, does anyone have any pictures / plans of the two cars listed below I could use to attempt to make my own scratch built bodies:
Bentley Embiricos Le mans 1949
Adler Trumpf Le mans 1937/38
Any help with wheelbase and track dimensions would be very helpful
I'll keep you posted of my progress.
QUOTE (MAF @ 28 Jul 2004, 08:55)Hi, I've started researching the following cars with a view to attempt to scratch build them, does anyone have any pictures / plans of the two cars listed below I could use to attempt to make my own scratch built bodies:
<{POST_SNAPBACK}>
MAF, I have plans and photos of both of those cars. This is the first time I've used this forum so I am uncertain about how it works. Can we private message each other? Glad to send you infomation. ettore
Hi ettore, welcome to the forum. I have sent you a personal message.
Marlon.
Hi Alan,
For these I've decided to make everything myself as to my knowledge nothing in 1/32 scale exists for these. I'm currently modelling the body of the Bentley from scratch which I'll then make a mould and resin cast (waiting for the first mould to set-up as I type). I'm taking photo's of the progress as I go along and will post what I've been up to soon.
The biggest problem on these cars is the lack of scale info, especially the Adler. I managed to find some good and accurate info on the Bentley, its big, with a wheel base of 126" and track of 56" which equates to 100mm and 44.5mm respectively in 1/32.
Best regards,
Marlon.
1 - 9 of 9 Posts
