Firstly, thanx to all for the feedback and compliments.
As I have learned so much on this forum, I think it is high time for me to plough something back, although very small.
I like to share the designs, all I ask is that if you add additional livery designs of your own, is that you share it as well with the members!
Thanx to Geezer for his banners that I have used/abused some of.
Following posts of how I made the perch:
The first to notice is that the cut outs were designed to be stuck on 1mm cardboard. (I think it is about 300g/mm2)
I have used A4 size label paper (self adhesive) to print the cut outs on. Normal or better quallity paper ca also be used, then stuck on the cardboard.
The next to notice is that I have made the base out of balsa wood, using a a piece of 36" x 1/2" x 1/4", cut into 70 mm lengths. Pictures to follow.
The pillars were made of 2mm dia kebab sticks.
I have uploaded the cut out files to Dropbox. the pdf files are huge, I do not know how to get them smaller" Help please?
I suggest that you download the Powerpoint (pptx file) slides, and print them. It will then also allow you to change and make your own preffered livery as well as change the size of the perch.
The link to the pptx file is here: http://dl.dropbox.com/u/61761872/Pitwall%20ver2.pptx
The link to the plan - front and side view - is : http://dl.dropbox.com/u/61761872/front%20%...side%20view.pdf
I'll post the links to the rest of pdfs a little later.
the detail steps - picture intensive - to follow.....
Enjoy!
TK
Enjoy!
TK
