Here's a slightly off-beat enquiry!
Are there any engineering people on board who could advise on how to measure the Inside Diameter (ID) of a cylinder the size of a full-size car tyre ranging up to a large dump-truck tyre, to an accuracy of one mm?
Outside Diameter (OD) is easy, using a tightly wrapped tape-measure to obtain circumference and dividing that figure by Pi to obtain diameter, very accurately.
But ID is a different ball game altogether.
It's far too difficult, well-nigh impossible, to run a tape accurately round the inside circumference as per OD above.
Trying to obtain a direct measurement across Internal Diameter is full of pitfalls.
A tape is too difficult to position and read accurately - useless!
We have used a £50 laser, which was not even accurate to 10mm - useless!
We ae now experimenting with a telescopic 'pole' (Nedo Messfix) which is accurate enough, but rather heavy and hard to handle in awkward confines - It has promise. It would be a LOT better if it were spring loaded and with a small ball or wheel on its end.
We are also experimenting with a £300 Leica laser, accurate to 3mm but need to improve on that - this also has promise and is by FAR the easiest of all to handle.
My gut feeling is that an accurate 'measuring wheel', to obtain Internal Circumference would be best of all.
Tiny ones are commonly used to measure scale distances on maps, but these are really TOO small for my needs.
Larger ones are used to measure fields and roads etc, but are way too unwieldy and inaccurate for my purpose.
I found a small/medium sized wheel, used for measuring carpets, but it its accuracy is no better than 10mm.
All measuring wheels discovered to date are impractical for the reasons listed.
But I suspect there will be something suitable, if only I knew where to look . . .
So, suggestions would be VERY welcome!
Oh, the range of diameters required runs from 300mm to 2300mm.
