This is a quick guide to how to photograph a slot car. I use a 4 year old Fuji MX-1200. It is perfect for web work and has a macro setting which is essential for close up work. You will not be able to take any pictures within 600 mm of your subject unless you have a macro setting on your camera. If you have a powerful camera then for web work you will have to reduce the image quality if you want the upload time to be respectable. With my Fuji MX-1200 I don't need to do this.
Lighting is very important and you will see from the first picture that I use a 500 watt halogen floodlight. This is ideal for macro work and provides enough light to flood the background. Without this your background will be dark if you use your flash. You should always use your flash if you want good close up images with the macro setting.
A cardreader and a ubs port are essential for speedy transfer of your pictures to the PC. The software that comes with your camera is normally OK for photographic editing but if you want any fancy effects then you will need to purchase additional software.
Simply store the shots you want to keep in a file on your PC and download the pictures to a photographic host on the internet, such as StarPhoto, when you want the world to see your masterpiece.
I will let the following pictures do some of the talking.
First shot with standard lens and flash:-
Second shot slightly closer with standard lens and flash:-
Third shot with macro lens and flash:-
I hope this is helpful.
Moped
Moped
