1 - 6 of 6 Posts
David H
The magnets fitted to the version of the Taurus you have are quite difficult to remove without marking the underside of the chassis, because the glue used to retain them is very efficient, a stretchy rubberised glue similar to Evostick contact adhesive.
Rather than trying to prise them out with a screwdriver, I use a hot soldering iron fitted with a narrow round tip to melt a neat hole from the inside of the chassis in the centre of the magnet pocket, and then dislodge the magnet by pushing a screwdriver firmly through the hole. If you don't want to use a soldering iron, you can drill a hole instead.
I use my teeth!
Because I, I am a VIKING!
1 - 6 of 6 Posts
