Hi. I'm brand new to HO slot cars, in a way. My parents found the track I has as a kid. It has been in an attic for ~20 years. I am surprised by the quality of plastic used for the track. I have all the pieces to the track, but the picture below shows I'm missing 1. It was fun piecing it together like a puzzle with no instructions.
The issue that I have is that the car does not run on the track. I've notices new cars have a motor cover and I'm not sure if it's required. I would like to know for sure a new car will work before I go and spend $30 on one; these suckers ain't cheap.
When I lift the rear wheels they turn. I thought the contacts were bad so I used fine sandpaper until I saw clean copper. Try again with the same issue. Next I took just the powered piece of track and let the rear wheels hang off the edge with the contacts on the rails (like this image), the car parallel to the track like it should be, and the wheels spin. Now I know it's not the contacts. So I thought the track is disrupting the magnets on the motor causing it not to spin and the motor cover blocks the magnet disruption. So I cut out a piece of cardboard put the car on the track and the wheels spin, woot. The only problem is the cardboard is ~2mm too thick so the wheels are off the track.
Is my car dead?
tl;dr; I think the motor magnets are busted but IDK. If I block the track from the motor magnets the motor spins.
Note: the transformer and track reads 20VDC as it should.
Track: 1993 Tyco Ultra Cliffhangers
Car: original with the set.
Car Underside
Motor Test
Is my car dead?
Car Underside
Motor Test
