QUOTE (MajorMagless @ 1 Feb 2015, 10:51)
<{POST_SNAPBACK}>So it is. I'll go with this one then:
Scalextric Lotus Exige R-GT #16, C3520
Good choice.
QUOTE (Wraith @ 1 Feb 2015, 14:38)
<{POST_SNAPBACK}>Can I use a bit of neodidum as weight?
Of course I'm joking
The same weight of anything is the same weight of anything.
QUOTE (Mr Modifier @ 1 Feb 2015, 14:40)
<{POST_SNAPBACK}>The WIDTH of the rim.
The DIAMETER of the rim excluding the ridge in the middle.
The WIDTH of the ridge in the middle.
The DIAMETER of the ridge.
Just picked up my Exige:
Rim W: 8.3mm
Rim D: 15.8mm
Ridge D: 18mm
Ridge W: 3.3mm
If you have a tire that's a little small should be fine. Once glued and trued, it will be good. Too large, and it can't be glued down properly. But, it's your call. I've been wanting an Exige, anyway.
