1 - 8 of 8 Posts
hi guys i seen a track layout in the forums somewhere called "kingsley motor speedway" i am sure it was using carrera track also is there anyone out there that can confirm this ?
if so could they put it in there track planner and tell me what the dimensions of the base board i would need as this is the layout i would like to build
my sport layout went a few days ago £350 yiffa
but was very sad also
but i can start thinking about building again now !
any help would again as always be appreciated
thx mate that is what i wanted and diden't want all in one fell swoop that is the artical but it is in scalextric track
i want to use carrera
maybe i will try the carrera layout further down the list it looks ok i can probably make it a little longer as i may have more room now than first thought
unless someone could tell me if that kingsley layout would work using carrera track
Yes, there are different curves and straights used, but they are all Carrera track parts. The small straights are 1/3 AND 1/4 straights. The curves are still the same radius but a 30 degree arc instead of a 60 deg. one
The reason they show up light grey is because I have input into the planner database only those parts available in 5 or 6 Le Mans sets. The planner is flagging up that I do not actually have those pieces
Mark.
1 - 8 of 8 Posts
