1 - 5 of 5 Posts
Feel like an idiot asking this but....
i agree with julian, except if youve got a good puller you can remove it again. if your not comfort able with this, use a 5-6mm wide diamond file, remove the splines with the motor running fast. you will still see the indents of the spline on the shaft, but the high spots have been removed. incidently you cant press a steel pinion on, you have to remove the splines. john.
1 - 5 of 5 Posts
