1 - 1 of 1 Posts
Russell Sheldon
Finally, you no longer need to lug around a 220/240v to 110v step-down transformer!
Koford now have a 220/240v 50 hz version of the M325H compact portable power supply available, stock number M325I.
The M325I generates up to 12v output and up to 20 amps (yes, 20 amps!).
It measures a compact 4" wide (101.6mm) x 5-1/2" (139.7mm) deep and is 3" (76.2mm) high. Weight is 2lbs 14oz (1.3kg) and it comes with a 2-pin European standard plug fitted.
The power supply is regulated. Basically, what this means is that the power output is regulated, so that as a motor breaks in, the output voltage remains constant.
It also has with a digital read-out (LCD) and a cooling fan. The LCD digital meter reads either amperage or voltage, with a flick of the toggle switch.
The retail price is $305.32 and orders can be placed through your regular retailer.
With kind regards,
Russell
1 - 1 of 1 Posts
