1 - 14 of 14 Posts
Thinking of integrating Oxigen into my wood track.
I've been put in touch with someone who is going to be making a lane change flipper device with a solenoid. I wasn't sure if this would work with Oxigen though. Is there an Oxigen component that will work with the solenoid/flipper for an Oxigen lane changer or am I kind of stuck with trying to integrate a Scalextric (or other digital brand) LC into my wood track?
Thanks,
Pete
You can buy the oXigen Lane Change board. It powers the solenoids directly, and can work in a couple different modes. You would not need to purchase any SSD parts to install O2 into a track such as the example above.
QUOTE (Slot.it @ 1 Aug 2012, 02:28) <{POST_SNAPBACK}>We are currently checking some solenoids in order to provide it as a spare part.
If you can help me find a solenoid that is a match size to the one's found in the Scalextric SSD X-Over, I'll definitely buy the O2 LC board for my project to convert my SCX-D track to SSD / O2. (I know what some of you are thinking but it will work to make the SCX-D mechanical changers into electronic one's).
I'm having a very difficult time finding a pull type solenoid with the body diameter of 1/4" (6mm) that would fit nicely under my track. So any help would be appreciated.
Dave
QUOTE (Slot.it @ 1 Aug 2012, 11:28) <{POST_SNAPBACK}>We are currently checking some solenoids in order to provide it as a spare part.
Hi, did this finally happend? I am converting my friend's SCX-D (SDS here in Spain)) into oXigen. We have allready a few lane changers working allready but we are using ninco solenoids for now and I was wondering if it's possible to buy them from slot.it or we could know any solenoid reference that could be simillar in shape and size to ninco's.
Thank you very much!
Vendor
Richard,
we are still working on this: we hoped to be able to provide rapidly a solution for wooden tracks, but it hasn't happened yet as we didn't get the answers we needed from the supplier. In any case, give me until next Monday and I will let you know. I also know that we've tried some PECO solenoids and they can be driven by our driver.
Vendor
You can use either one of the solenoids in the PECO unit. Each solenoid has got two pins (one is doubled, but electrically it's only one), use them as if it was any other (Ninco, Carrera, etc...) coil.
Maurizio
1 - 14 of 14 Posts
