1 - 8 of 8 Posts
I've got a few SCX tilting cars and most of them suffer body - tyre contact when cornering.
Does anyone have a fix for this? I'm not sure that my idea of gluing the motor cradle to the chassis is the right way to go. I suppose that even limiting the tilt would be fine, if it's feasable.
TIA
Stuart
David Collins
At Wellingborough we commonly put tape (hazard tape, like you use to clean your tyres) across the motor pod under the chassis to limit and dampen the amount of rock. It's generally accepted to be a performance enhancement, but the effect will be different on each chassis. A simple thing to try and test. But perhaps sanding your tyres down, and moving the wheels just slightly inboard (trimming the axle length might be necessary for this) would also be worth looking at.
Thanks everyone.
Tore, I'm liking your solution. Having said that, I'll probably have a go at putting something under the bearing brackets.
Yet again, the solutions are obvious. Why is it I can stare at something for hours and not see what I need to? I post on here and within a short time the answer I should have come-up with for myself is given to me.
Stuart.
QUOTE (StuBeeDoo @ 29 Oct 2011, 11:19) <{POST_SNAPBACK}>Thanks everyone.
Stuart.
It is the collective
1 - 8 of 8 Posts
