QUOTE (StuBeeDoo @ 26 Jul 2011, 20:02)
<{POST_SNAPBACK}>Reads like you could be thinking along similar lines to me. Short track/long track, similar idea to Brands Hatch????
I asked a similar question here a while ago, and got the following reply........
You've got it - long flowing track with twisty rally loop. I want to be able to run a long open track but occasionally add a rally style extension with tight turns, elevation and surface changes. The long track stays down full time and the rally track gets laid out whenever. I suppose I could just break into the main track but the SSD pit entry/exit pieces seem to offer a more elegant solution.
I had thought of wiring up the flipper mechanism to a simple supply and just use a normally open/closed arrangement for loop or no loop. Are the actuators simple solenoids and what voltage do they work at?
MrFlippant's idea of tape seems like a good starting point though, might give that a try before I get too carried away.
Thanks for the answers so far.
