1 - 7 of 7 Posts
· Senior Slot Car Mechanic
QUOTE On another note, when will you be making your beautiful machined brass 'U' brackets available for the BWA Minimotors, please?
As soon as someone puts up 4,000K$That's what the big brackets cost to do.
The Mini motor will actually fit the big bracket,if you rotate it about 60 deg from horizontal.If I ever do manage to put the little bracket into production,the motor will probably sit vertical rather than flat.The whole gubins should be no more than half an inch wide.
· Russell Sheldon
I can't help thinking that if the manufacturers, Fly in particular, were to use the Mabuchi FF030PA/PK mini-motor, we would have 1/32nd scale Lola's, Porsche's and Chevron's and Scalextric wouldn't have to do this:-
The motors cost less than $1.00 wholesale....
Kind regards
Russell
1 - 7 of 7 Posts
