Why am I doing this? I don't know. Must be like the moutain thing: "because it's there" In any event, inspired by the photos that Russell posted and having a Strombecker shell around, I decided to give it a go.
First things first - wheels (I always start with the wheels - probably a hangover from 40+ years ago when suitable wheels were the biggest problem) The parts bin yielded a set of 1/2" SCD wheels for 3/32" axles with set (grub) screw fixing and a little further investigation turned up some suitable Lotus inserts. so here is the start:
A pair of the SCD wheels and Ortmann tires (Goodyear markings to boot!), a piece of 1.75" X 4" X 0.0625" brass, an angled spur gear (39 teeth - provides the requisite 1/16" ground clearance, and a TMM (Taiwan Mystery Motor) , a Moto GP look-alike and the body with the wheel opening work started.
A little layout work and we begin:
Documenting the absence of lasers
No bits were broken in producing the following!
Wheel and wheel/gear clearance cut, slots for the two rear axle carriers and an opening that has nothing to do with motor location (there is a limit to how much mass I'll ask that little motor to haul around!)
Soldering started!
Starting to look like a slot car! I'm still debating the method of motor fixing. The body has moved on a bit - molded in driver, passenger and steering wheel gone, LH side of cockpit reshaped to the passenger-unfriendly contour in the plans (above) and an instrument nacelle added. I am still pondering the best approach to doing the rear air intakes.
To be continued.......
EM
Soldering started!
EM
