1 - 13 of 13 Posts
Al Schwartz
Can anyone suggest a source for a drawing of the Cosworth Ford V-8 including the transaxle assembly? I have been doodling some ideas for a Lotus 49 and have come to the (preliminary) conclusion that a reasonable approach would be to saw off the rear of a Fitzpatrick body (thank you, David, for the idea) and build up the engine-gearbox assembly as part of the model's motor/gear set part. I expect that I shall need to distort the power train to some degree to fit the bits in but would like to have the dimensions of the prototype - block length, height over cam covers, width over same and the size, shape and axle centerline of the transaxle as a starting point.
If this avenue works, my next steps (again, preliminary) would be to attach the suspension bits, including the trailing arms to this motor/chassis component and then do the body shell, with front suspension attached, as a separate part, hinged at the rear with a simple limit stop at the front. This seems to me the easiest way to model the "clamshell" front of the car which, from the photos I have seen, has the body shell extending under the front suspension. (Yes, I am an adherent of the "tripod" school of chassis design)
Thanks for any help.
EM
Al Schwartz
Thanks, Russell - I can scale most of what I need from that drawing. I have a series of good photos of the engine but needed to establish a few "hard points" like distance from the front of the engine to the axle center, height of axle relative to upper and lower engine surfaces, etc.
EM
I've searched my books and magazines but surprisingly couldn't find a drawing of the DFV other than a nice 3D cutaway.
If it helps I measured a Tamiya 1/12 Cosworth and ZF gearbox from the Lotus 49 kit as per Russell's drawing.
Block length 50mm
Gearbox length 47mm
Engine height 41mm to top of the cam covers
Engine width 59mm at the bottom of the cam covers
If this is useful just ask if you need any other measurements taken.
Al Schwartz
Thank you both - David's numbers match, within my measurement error, the results that I obtained by scaling the drawing so I'm comfortable that I have the basics - now all I need to do is see what will fit (and how to do 0.0625" high raised letters to spell "Ford" on the cam covers!)
EM
I know this is going off topic a bit, but it's not worth sarting a new thread:
Been meaning to ask this for ages, but Russel, do you have pictures of everything? lol. Anytime someone asks for a picture, you're right in there with one instantly. Your hard drive must be packed...
Lotus
PS. After Russel's response feel free to continue the cossie talk.
Better late than never EM, I forgot I had these drawings in the "History of the Grand Prix Car" by Doug Nye - they are the general arrangement drawings from Lotus.
Al Schwartz
Wonderful idea, Ice - I'm just doing some valve cover drawings so I should have the dimensions soon - so far as "raised" is concerned - I'm guessing that the lettering on the prototype is no more than 3/8" high - in 1/32 that would be just over 0.01" - If anyone wants to go to "scale war" over 10 thou, I shall relegate them to some form of scrutineers pugatory where all measuring devices are elastic!
I may even have a trade that would interest you - do you recall that Tamiya re-issue 246 that we were both bidding on a little while ago?
EM
1 - 13 of 13 Posts
