"Once upon a time" (actually, not all that long ago) while wandering through the dark forests of eBay, I came upon an offering for "hypoid gears". Not having seen such wonders in the realm of model parts, I though to myself "Some fool has misspoken, he thinks that "hypoid" and "bevel" are the same". Still in all, the asking was a mere pittance and my stocks of bevels were meager. I offered and won and shortly thereafter, several bags of golden hued parts were in my hands. With wonderment, I realized on inspection that they were, indeed, hypoid gears and by careful restoration and translation of the ancient runes, I discerned an ordained offset of 0.125".
I don't know what the offset of the new Slot-It gears are but 0.125" is a signifficant lowering of the heavy bits and I was anxious to try them. Of course, first we do the numbers: A typical can motor is 0.6" high /2 = 0.30". We drop this 0.125" below the axle center and the bottom of the motor is 0.425" below the center. A typical ground clearance requirement will be between 0.0625" (1/16") and 0.0787" (2mm). Adding those numbers to the motor bottom number, we get 0.4875 - 0.5037 as the tire radius or 0.975 - 1.0074 as the required rear tire sizes. Pretty much pre-war and a few immediate post war GP cars -I hardly know anyone who likes to model those!
I have one or two Benz's and a pair of Alfas - but no Auto Unions. What I do have is a pair of kits - one Matchbox, one Revell D type AU - appear to be the same, I don't know which is the chicken and which the egg. So the design process here is a bit backwards. Instead of deciding a prototype and a motor and then finding gearing to suit, the gears dictated the era and a range of protoypes.
My initial thought was to use a Pittman motor- sort of "emotionally" suitable to the gears and the car but while pushing parts around on the bench, I realized that, if I shaved the rear axle assembly to minimum length, an FK series motor (eg TSRF, Fox etc) would fit completely in the rear compartment, allowing a full cockpit.
This choice raises an issue: the gears are clearly 60's 1/24 stuff - the axle gear has a 0.125" bore and the pinion is 3/32". Some time ago, I came across an outfit specializing in "repowering" parts for model trains:
A-Line
They make neat little brass bushes that are 3/32" OD, 2 mm ID.
The rear axle carrier had to be made - the gears are too wide to fit the pre-made ones (e.g. BWA) that I had in hand. After taking a chunk of brass and cutting away anything that was not shaped like an axle carrier, I mounted the motor and gears for run-in:
As it turned out, hours of run in! When I first mounted the gears, I was convinced that I had gotten the measurements wrong or mounted the gears backwards. Turning them was like rubbing rough stones together. They are not really an example of precision gear cutting. After several hours of low speed running with regular applications of tooth paste, things began to smooth out. The current draw seemed well enough under control to let them run overnight. by morning, I had a very smooth gearset.
I added a little "parcel shelf" to provide a rear body mount and to make sure that the bracket didn't flex:
Still needs to be cleaned up:
The rest of the chassis is straightforward: 0.047" music wire, bent into a "U" supports the forward section with the guide pivot and the front suspension is a short pivot swing arm soldered to this forward plate (0.0625" brass):
The motor/axle offset is obvious in this shot.
To be continued......
EM
A-Line
EM
