Jaguar D Le Mans´54 there´s 4 mold body type :
replika1.evo0.s2evo1 with Kako 3,5V motor
replika1.evo0.s2evo3 with Mabuchi 15r long shaft 12V motor
replika1.evo1.s2evo3 with Mabuchi 15r long shaft 12V motor
replika1.evo2.s2.evo3 with " another " unknown " motor
replicates the 1º evolution of body of the second model Strombecker, also the first model Jugarama will have up to 3 changes in its body, resulting in up to 4 different body types.
The fact that there are up to 4 body types does not follow a fad, but it addresses the need to adapt. The key factor in Jugarama is not quality jugarama, but the manufacturing economy, the most expensive part was the engine that were imported from Japan.
The first body still without changes (
type 1) is in the proper hooks to accommodate the engine side magnets problematic Kako of 3.5 V.
( sorry, this unit ist broken )
When allowed to import the old engine is replaced by Mabuchi 15r in its long axis, a 12V motor and better performance but not without problems because it was so bulky, it creates the need to change the hooks (now the holes for the above motor magnets are blinded) and the pilot's cockpit (is trimmed in length). It also changes the guide and the crown. That´s
type 2.
In a second evolution (
type 3) it improving the attachment of the body and chassis. The solution is as emphatic as it is effective: it adds a pivot that is the role of being the female where a screw is screwed. In addition, the chassis since then have holes to facilitate the passage of the screw. Yes, there is a screw and 2 holes, but remember that the chassis was common and the other hole was used for screwing in other models as we shall see later.
Finally, Mabuchi motors are no longer used and are then replaced by a 12V motor of unknown origin (Japan, Mexico?) Closed with wound-type green and not so great as Mabuchi. The body was modified again for the third time to
type 4 of the same mold. This time cockpit is trimmed in depth, because the new engine has a central position and not back as before, since that engine does not use a long shaft.
