OK, I've put in a scaleauto sc-07 motor into my car and it's going VERY fast... Just how I like it.
Trouble is, my 45ohm controller makes it uncontrollable and I'm getting that 'twitchy' feeling when I raced it last night.
I used John Secci's'controller with a hundred dials'
and he manages to best this beast so it is drivable again. Kudos to him!
Anyone else try the sc-07 35,000 rpm motor (The car is non-magnet BTW)? What Ohms did you find you ended up using to keep this under control? Or did you choke your controller and run lower volts maybe? Maybe something else?
I cannot remember the pinion and crown settings I used... Suspect it's 9~27 (3-1) but it might not be....
