1 - 7 of 7 Posts
Hi, has anyone tryed to fit a ninco type motor into a scx motor pod??, i"ve had a go but the motor shaft is to short, the only motor i"ve got which has a long shaft is a cartrix tx-5, but i would still need the adaptors, who make these?, the car that i tryed this on is scx nascar fitted with the rx-42b.
· Nobby Berkshire
QUOTE When fitting a long can motor into the SCX pod I space the axle so that the motor shaft is not required to hold centre the axle in the chassis
That's the way to do it. You can use brass tubing either side of the axleshaft or simple spacers between the wheel and bearing. Easy.
Otherwise you'll only have a tiny range of motors with a long enough shaft.
The NC 7 (raider) motor fits no problem due to it having a longer shaft, I've got one in an scx mk2 escort, but to be honest you might as well use an scx pro speed motor, 25,000k and much better than the 42b scx motors.
Thats the motor!
But I've found on our 100ft wood track they perform great, and no real problem with brakes.
I've used 4 so far in 2 Mk2 escorts and an LMP and an F1, the only one which is a little tricky to drive is the F1, but I'm sure could be recified with different gear ratios.
1 - 7 of 7 Posts
