I have a Slot.it sidewinder motor mount/pod where the front two holes became stripped and oversized for reasons that I cannot exactly remember. In an effort to get it back to where I could use standard Slot.it pod screws, I decided to try and fill the holes with an as similar as possible material that I had on hand, PLA, using the hot end of my Ender 3.
I loaded up the printer with some black PLA, set the hot end to pre-heat PLA mode (185C) and let that heat up. I then placed the bottom of the pod hole on the edge of my printer bed, lowered the nozzle into the top of the hole and then manually fed some of the PLA through the nozzle. I raised the nozzle and the hole was pretty much filled with PLA. I completed the other hole and let the PLA cool. I then drilled out the holes with a 1.6mm drill bit and Slot.it screws were screwed in as if the pod was new!
Peter
Peter
