Due to suffering the same financial problems as everyone else seems to be I've been selling off a few cars (which has been quite interesting - more later). Looking at my collection my MRRC 4 wheel drive hasn't turned a wheel for at least 10 years and is not likely to do so in the next 10 so was a good candidate for sale.
A quick examination showed noting much wrong but the paint job was showing it's age and everything was a mixture of fluff, dirt and oil so a full overall was in order before sale.
As I took a number of photo's during the build up I thought some of the younger forum members might like to see how these cars fit together. (As this car is currently for sale the Mod's may feel this constitutes advertising and want to delete this thread.)
It is possible to break the motor down by bending the tabs at each corner but experience has taught me that it never goes back together tight enough so the motor unit was just cleaned up - had the bearings flushed and was re-lubed using molyslip.
The plastic frame is held firm with pressed steel brackets - at the front they also carry the stub axles.
Well - that's a start - but my photos are taking a while to load to PhotoBucket and it won't make sense to go further without a photo of the stub axles. So more later if anyone's interested.
Mike
In the above picture the recesses for the ball bearings can be clearly seen.
Doing the front bearings is quite easy on the first side. Just tap the axle in one of the drive cups and slide it into place trapping the ball bearings (don't forget to fit the smaller bevel - the right way round) this can then be held in place by tightening the bevel gear.
The other side is more tricky as the cup needs to be pushed on the other end of the axle until there is just enough space to place the balls in the recess. Then the whole lot is pressed in a vice until it is free to revolve but has no slop.
Mike
