Shout out to @MrFlippant
I have four of them to add, so probably wherever there is a straight section towards the end of each segment. Possibly one at the beginning of the straight leading to the pit entrance, but having this on my last track I had it too close to the pit lane change, so on this track there should be enough space to have it a short distance down the straight on that section. Could always disable the switch to the outside lane if that becomes a problem to allow that last chance to pit.Do you know where you are going to put lane changers?
It really depends on how you put the lane changers in the rooted track.How do lane changers work in routed track? The same as plastic track using the same buttons on the wireless controllers etc.?
Yes, it will operate the same. The advantage being how the crossover curve can be extended for smoother lane changes and placement options.Love the curve in the upper right. Very cool looking, almost a Nautilus / Fibonacci spiral.
That's what I did on my last layout, however the plastic track had some abrupt kinks in the overpass which I did not care for. It is a great idea.Pit buildings could be placed underneath the track, saving space, and giving you much better visibility. Check this out for inspiration
MID-BC
kelownaslotcar.com
Yeah, I debated on the depth. due to the digital parts, the depth is around 6mm, which matches the sport track. I wasn't sure about recessing the switches into the track if I wanted to power them and didn't want to have a situation where the sensors would be too deep or get smashed. Also, my Bentleys have deeper guides which tend to scrape on the plastic track and they clear fine.Wow, those are really clean cuts.
They do look a bit shallow though. I don´t know what depth you are running, but I really recommend 9 mm or roughly 1/3 inch, as this will clear almost all deep wood guides.
Again, I might be wrong.
Keep up the good work!
Got it. Thanks @Nolakers for correcting me before I got too far on this. As it turns out, I was able to reposition the scrap piece and clamp it down, reusing the nail holes for the template. Worked beautifully, the slots are now going to be 5/16" deep. I'll figure out the digital parts later. Thinking I can just put a washer or two under the flippers if they present a problem. Also I'm hoping that the extra depth won't affect the sensors or the analog lane counters.As long as you stick to OEM guides, you will be fine. Although wider and deeper wood guides really do help in keeping the car in the slot, and while its enough now, you dont want to be stuck with shallow guides.
If you can go deeper with the LC's still working, do it
