Analog Terminal Block / Controller Stations
Having run (Carrera) digital for several months I found I never used the digital aspect and when I switched to more of a commercial vibe layout I decided to drop digital completely. For me the more old school the better. Instead of adding two lanes to my existing analog wiring I decided to start from scratch. My abilities are limited however I can struggle through and when it eventually works there is undeniable satisfaction in knowing you constructed it.
With a lot of help from Professor Motor as I used their Wiring Center, Controller Hookups, Wire and Boost Clips. The only things I purchased elsewhere were the DPDT switches to reverse direction which I received from Amazon along with the power supply. Having built a two lane version from scratch it was pretty straight forward since Professor Motor had already wired one side of the terminal block. Luckily once completed all four lanes tested out 100% which made my day!
For controllers I have been using Professor Motor PMTR2111 recommended by Greg and they have been working like a champ so I see no reason to change. Might order two more, run some jumpers at the controller posts (if possible) or simply swap the controllers around as needed. I have an aversion to mounting anything on the layout tables (since I often change configurations and I know it's strange
) so I picked up a IKEA (cheap) table and mounted the board angled upwards just a tad. It's plenty secure as it slides into the brackets and they are doubled-sided foam taped to the table.
UPDATE: I decided to purchase Slot.it SCP201ai Universal analog controllers and sell the Professor Motor controllers (nothing but good things to say about them). I like that they have a contactless magnetic trigger system and figured since I'm starting over with the track why not the controllers too. For now I'm jumping lanes 2 & 3 and lanes 4 & 5 so I can use the same controller on both without continually swapping controller from lane to lane. If for some reason I want to run the jumped lanes separately I can remove the jumpers.
Having used the new controller for several months I have been impressed. I like how the adjustments have reference numbers so you can use the exact same settings per car. As it makes it easy to go back and forth. On top of the typical adjustments minimum power and sensitivity really helps to adjust the car's performance per the layout.
