Hi guys,
I hope this isn't gonna sound too complicated:
I've recently purchased a PM controller for my Scaley sport set and it runs beautifully without a single problem..... until now. Since the controller is for use with Scalextric sport tracks, a 3.5mm jack was already installed. Now I've decided to use the controller at the club as well as at home, so I would need to create some kind of adaptor to enable the switch between the 3.5mm jack and a 2amp 3-pin plug, for use at home and at the club respectively.
Anyway, I managed to make the adaptors: I cut the wires on the PM controller (3.5mm jack) and I also cut the wires on my 35ohm Parma controller(which is installed with a 3-pin plug). Then I soldered the wires up with some RC car battery connectors (one end is male, the other female). So the end result was that I could plug in either of the adaptors according to the track:
__________female adaptor----3.5mm jack
Controller----------male adaptor---------
(PM or Parma) |
|__________female adaptor----3-pin plug
So you can see there are 4 possible combinations, however, one of them fails to work:
-Parma controller-----------3.5mm jack (works) [Scaley track at home]
-Parma controller-----------3-pin plug (works) [SCX track at club]
-PM controller---------------3.5mm jack (works) [Scaley track at home]
-PM controller---------------3-pin plug (DOES NOT work) [SCX track at club]
The actual problem is that when the throttle is 100% open, the car has some movement, but when the throttle is at ANY other position, nothing happens. (This only happens when I try to use the PM controller with the 3-pin plug in the club. The PM works perfectly with the 3.5mm jack at home)
Honestly guys, I don't even know where to start......I need some
Apology for such long post, thanks for reading (if you made it this far).
Cheers.
(PM or Parma) |
Cheers.
