hi tony if you run on a wooden track you do not need wieght, on plastic, a little helps just behind the guide{not too much} as graham said tyres should be pro-slot with a little 3in1 oil or as i use fly " d " compound with oil, dont forget to put a little rad on the edge of the tyre to stop it digging in on corners, the rear axle on the fly porsche needs some work, change the gears to slot-it with large dia slot-it wheels,make up 2 sets of wheels, 1 with pro-slots, 1 with fly "d " compounds see wich is best. if you use a 10 tooth pinion and a 24 tooth crown wheel this smooths out the cars handling and gives a more predictable car, in the porsche chalange at pendle last month this was producing sub 8 second laps, hope this helps cheers mac p
