I need to sort out my power as it gets a little ropey toward the back of the layout. What is the best way to power Scalex classic track for a permanent layout? Is it best to solder every joint or solder a jump cable across every joint? Or is that over the top?
I intended to divide the layout into 6 easy to manage (manoeuvre in my confined space) sections and then solder little jump cables across the underneath of each joint in the section. It seemed easier to then put them back on the layout in whole sections and put separate power taps to each of the six sections. Any better ideas these days?
Mark
Mark
