A simple and reversible way to disconnect the motor from the strips while maintaining their suspension properties is to put some heat shrink tubing over the little feet on the motor that contact the strips. This will isolate the motor from the power coming off the rails.
Then, as you surmised, tap the power to the chip off those rails. Be quick about it, as it's easy to melt the underlying plastic. Then connect the chip output to the motor as normal.
The lights on SCX cars are usually also connected to those rails, so make sure your chip does not interfere with that system. Fortunately, most of their cars have a shallow interior, so plenty of room for a chip to be installed. Some will even have stub axles, giving you even more room.
And finally, yes... those motors are a little much for the older scalextric solder in chips C7005 and C7006, especially if you want to keep the magnets in. Either pull the magnets, or use a heftier chip, such as the most recent DPR chip (which you can remove from the DPR plastic panel) or the slot.it SP15b (or SP15c) chip.
Make sure metal things that should not touch CAN NOT touch, either by shrink wrapping or electrical tape, or liquid tape, and you should be fine.
