1 - 12 of 12 Posts
looks fun, specialy the twistly bit at the bottem, but it seems like a lot of space for a small ammout of track? could be difficult to reash one site if its against a wall?
thanks for your reply
there will be a space in the middle, the track will run around four walls of a box room
David Moss
Cool! I like it. I like it a lot!!!
Looks alot of fun to drive! In fact I think I'll try it myself, sometime.
Reminds me of my favourite circuit, Silverstone International.
Good luck with it. I thinks it's (a VERY unusual) winner!
BacardiBeast
G
Nice track design, but you get tangled up in your throttle wire when turning around to watch your cars! Lol
QUOTE (Domejuddv10 @ 6 Jan 2005, 16:05)Nice track design, but you get tangled up in your throttle wire when turning around to watch your cars! Lol
<{POST_SNAPBACK}>
That's what I was thinking too...
But I want to see it realised though! I'm very curious to see pictures from this project! Succes with the track!
Gunther
i mostly race alone as there are no clubs in my area, so blocking each others view will not be a big problem for me.
I am also thinking about a swivel chair, but this may cause me to get tangled up.
It may be the summer before I get the project off the ground, as i've got to empty the box room first.
Hi B1RAC,
I've always liked that concept for getting a bigger track into a small space.
A couple of thoughts I had when considering this type of layout.
- driving from the middle is going to be a pain, but having the middle open is great for landscaping and accesing all the corners so:
-- consider using all the walls like you have but cut a diagonal straight from one wall to another where your door is. You can then easily have 2 drivers stations, side by side on the outside of the track. Build this section of benchwork as a very narrow span. you will be "ducking under" into the centre to retrieve your offs - or if you're pretty handy, hinge it so you can lift the "bridge" to gain access...
-- the other though was to create a horseshoe layout with drivers stations at the end of each end of the 'C'. The track would have two passes along each wall - one up, one back - cross overs can make this type a pretty decent track, and you still have the center area open if you want.
Just some thoughts...
Ken R
1 - 12 of 12 Posts
