QUOTE (Robert V. @ 27 Apr 2011, 04:44)
<{POST_SNAPBACK}>Hey Guys, am i to understand that you can run the ninco Digital console at a lower voltage than the lane changers. I allso have a Variable power supply, mostly to slow the cars down. But because of the lane change function you require at least 12 volts , other wise they don't function properly. Would the standard digital controller when activated to do a lane change still work at 12 volts or higher if you where to operate the Console at a lower voltage than the lane changers.
I think i wrote that correctly. Thanks in advance Robert V
In order to get lower voltage on the track and a good working Lane changers:
Best option is assemble a SimpleH and power the track with a variable voltage power supply and power Ninco PB and Lane Changers prints with the original Ninco Power Supply. Dont forget to connect both Grounds of power supplies to each other. This is not the cheaper option.
Other options:
Power your Ninco PB with your variable Power supply, in this case I don't know the working voltage input for correct PB work, and power Lane changer prints with other Original Ninco power supply. Don't forget to connect both GND to each other PSU.
In all options always is a good business to build connections from track power supply to different zones of your track soldering copper cables in order to keep the same voltage in all zones, this can be done following a star design strategy or ring design strategy.
