It's been a while since I tried it, but yes, I get the same behaviour.
It's been a while since I tried it, but yes, I get the same behaviour.Maybe someone can verify my observations.
Does it trigger as soon as you press the brake, or do you have to hold the brake to make it refuel? I was not suggesting to hold the button(s) down, but just to click them every few seconds.Hi MrF
Thanks for the suggestions.
Brake is our fuel filling trigger, so that will not be one to use. I will give LC a try, but I do think this is a bug that slot it should look at.
It’s this that, in my mind, doesn’t work as it should.How to start BLE so that it can be contacted with the Slot.it app:
if your chip is:
Once this is done, the chip can be contacted by the Slot.it app. Press ‘Connect’.
- New (factory fresh, firmware 3.10 and later)…
- oXigen…
- SSD and D132: leave the chip on SSD track for 10” without pulling the controller’s trigger, then press the lane change button for 2".
I’ve mentioned this a couple of times, and this little problem has actually celebrated its first birthday. But yes, it’s easy that things get lost in this forum, and I’m positive. We, the community, simply need to apply some modern software practices together with slot.it, and we’ll be alright. I’ve wanted to start that discussion for a while, but have been holding back in order for the dust to settle around the last firmware updates, and let the everyone involved in oXigen 4.0 to focus on that first.@Slot.it maybe Maurizio/Slot.it should be made aware of this.
It is the first time I hear about this behaviour.
Didn't Alan replace those? If not, what was his reasoning?the 2 dead chips out of the 4 that I purchased.
One should be carefull giving advise in such cases.....Anyway, it has indirectly been acknowledged by slot.it, so I’m sure it will be fixed sooner or later!
He told me to send them to slot.it.Didn't Alan replace those? If not, what was his reasoning?
A small package like that would cost a lot less to ship to them than two more chips would.He told me to send them to slot.it.
I dug out the necessary hardware to test this, and I could not get any cars to go into DFU mode on a live SSD track, with or without the MAGIC app running a race or even being connected.Maybe someone can verify my observations.
What I mean with the above is that we need some proper issue tracking and release management in place. Simply something similar to what’s is available out-of-the-box in e.g. GitHub, i.e. public threads that are focused on issues, and release documentation that links to those issues when things get fixed.I did find a couple other issues that I believe are app related, and reported those to slot.it, but I don't think those issues are related to this.
