In post #20, Maurzio talks about the setup for switching between Oxigen and Ninco analog:
"If you have an analog Ninco track, you can convert it to oXigen digital and keep compatibility with analog circuit. Add LC sections, according to our instructions. Ninco's LC remain straight in analog mode so you can still use the analog track in analog mode. Then build a simple jack that must be plugged in the powerbase so that each lane gets full voltage from the power supply. Plug it in, and the track is ready to go in digital mode (PUT A FUSE - so you're protected against leaving a screwdriver across rails, for example. Remember you alway have full power on rails in digital mode). Then popwe on the controllers, put the cars on the track, and off you go. Tired of digital - remove the plugs, and put your controllers in. As simple as that. You need some magnets to do the finish line."
I am in the process of doing exactly this setup, but I would like more information about building the simple jack that shorts the powerbase to give full power to the rails. My Ninco powerbase is the one with the 1/4" jacks and separate power plugs. I can go to Radio Shack and get the jacks; and I already purchased the in-line fuse boxes and 5 amp fuses.
Which connections need to be shorted and are there any tips on making this relatively clean looking? I thought I saw another thread where someone had pictures of just such a modified jack, but I can't seem to find it again.
I just started testing the car, chip, and SCP. I have been getting full power to the rails by using a rubber band to hold the trigger down on an analog controller.
I know this is basis information, but I get nervous when it comes to wiring.
Thanks,
Kevin
