1 - 15 of 15 Posts
Well guys, after having painting all my 72 pieces of track. I now have to get rid of them all...down the trash, i guess. I really thought i had covered it all, by cleaning the track first before painting and also by adding a thin layer of paint. I was wrong, now the paint falls off. And i am almost about to...cry. Way to much work and money down the drain. Now i have to buy new pieces...i have done some stupid things in my life..but this surely tops it all.well, i will never, ever paint my track again.
Hi there
Yes nightglider1, the paint don´t stick to the track, and i really dont know why. I mean...i cleand it and then I added a thin layer of the primer, i only used primer cause i did not want to get to much paint on the track. And now the paint just "falls" of like "flakes". And it feels just hopeless, this is "killing" me. I have also tryed to get the paint off completely but I have not ben succesfull. Any ideas?
Alan Tadd
Larsson
Why do you have to throw the track away, is it distorted or damaged in some way?.
Can't you clean off the old paint with thinners or something similar and then repaint?.
This article from theSlot Forum archives may help :-
Track Painting
Don't give up, in the end you will get there.
Alan
Hello BEEJAY7
The track is not distorted or damage in anyway, I have tryed to get the old paint off but that is a huge work, really huge. But you are right, i can not throw the track away. Need to figure something out. Thank you helping me out as well as for the support.
Eric
Hmmm...that's strange. As I'm sure you know, the primer helps the paint stick to the track. I'd have expected paint to come off if the track weren't primed, but I'm sort of at a loss here...
Hope things wind up working out for you.
-- Pete
Is the paint coming off when you are driving on the track or does it come off while handling it? What type of paint did you use on it?
I only used a grey latex primer on mine and the cars never cause the paint to come off. It will scrape off though if I scrape something across it but that only when I am working on my scenery or something.
I recently had to remove the old paint from seventy two pieces of 24X15 inch greenhouse glass. The paint was years old, and was as hard as concrete.
I tried all the general methods, which were all very messy, so I tried warm water, and after a ten minute soak, it almost fell off.
It might work with your track. Just get the water hot enough... but not too hot that it will distort the track, then give a quick scrub with a ScotchBrite, or pan scrub.
HTH
Bill.
ListerStorm - the paint comes off when i am handling it, putting the pieces together
And the paint also commes off if the track pieces gets slightly bended.
I used a gray primer paint aswell, maybe the quality on my paint was bad
Monarco and NZSlotty- thank you for youre tips and idea´s too. I will try it on some track.
If the paint is coming off that easily (including the primer?) then do try giving it a nice warm bath...both Latex and acrylic based paints will peel right off after a bit of soaking.
I originally painted my Classic track using craft type paint - water-based acrylic - worked well, except it did have a tendency to scratch off - did the "soak job" on it and then spray primed the track with flat white and then applied the acrylic paint over it - works very well now - did it on my Carrera track with the same good results too. A helpful hint, if you're not doing it already, paint the track in sections of 4 or 5 pieces at a time...goes a lot faster.
1 - 15 of 15 Posts
