1 - 20 of 29 Posts
Policar track
With the holidays on, I have some time to post my track and starting layout.
I decided to build a track with Policar. I started with the drift set with a load of extension pieces to make the following figure 8. I got the layout off HRW.
The table top is made of the thinest OSB I could get, I believe it's 7/16 which i framed out with 1" x 3". For legs I was lucky to find a daycare closing and was able to get these IKEA adjustable legs for $5 each. From what I can see online they have been OOS on their legs for the past year.
I hope to get some carpet for the table top and some professor motor controllers to replace the stock Policar ones.
Table Wood Flooring Floor Tablecloth
Furniture Building Table Interior design Wood
Exactly what I'm planning to do. Those R2 look about the same radius as Ninco R2. A pity there isn't more choice of sets with R2 and R3 curves instead of the R1s. Have you run any other cars on the track apart from those in the set? I guess you'll be buying some borders?
Policar track
The table top is 4 x 16. I used 2 - 4 x 8 sheets.
I was thinking of finding a different way to make borders my self but let's see.
I'm going to make a race coordinator lap timing system this week.
Nice start to a track and a decent size of table for future expansion.Got a 16x4 table at the moment which may expand in the future...never ending slot car obsession!!!
It might be too late now or you may not have the room but I would suggest turning one of the 4x8 sheets 90 degrees to make an "L". This way you will not be as limited in your design/layout options.
Thanks Purelife, the size is close to want I want to build. Perhaps as PetesLightKits said, I'll try to integrate an L shape.
Now looking at wood material and sizes.
What are "borders"?
What are "borders"?
Run-offs that fit around the outside (or inside) of track sections. Enables tail slides and running 1/24 cars!
Tire Vehicle Font Automotive exterior Bumper
Tire Vehicle Automotive tire Car Automotive design
Policar track
I could maybe fit the L layout, room is a bit tight and my wife might kill me. But I would love to have a long gentle cuved straight .
I originally told her I was only building a 4 x 8 HO layout 😂
ParrotGod
View attachment 290405 View attachment 290406
Just to note that not all 1/24 will be able to race on a policar track no matter if you have borders or not.
1/24 small saloon cars like the BRM/TTS are ok but anything larger like GT3 cars will not be able to go side by side.
Policar track
I'm working on coming up with a new layout for the table top.
I would like to come up with some version of this track that @MrFlippant posted a while back.
I'm close just fiddling with what works and what doesn't.
David H
The first one is better (post #13), for three reasons:
1. The main straight is longer.
2. The S-bend over the straight will be more fun.
3. The straight needs to run under the S-bend, not over it, otherwise you'll be scrabbling around under the bridge to retrieve crashed cars.
A very long time ago, I had a two-lane Ninco track with an S-bend over the main straight, although my S-bend was tighter and more pronounced than yours. I thought mine might be too fiddly to drive, but actually it was really nice and flowed well.
My old track wouldn't fit into your space, but it shows the S-bend.
Organism Line Font Slope Parallel
Policar track
Discussion Starter · #16 ·
Thanks! I also prefer the first track I posted. But was hesitant on the S.
ParrotGod
Given the space you have got, the last one looks like has a good flow.
My current layout isn't too far off from the last you posted with the exception of the elevated "S and we've had a lot of fun with it. Mine is about 12' x 6' so similar total length. I used R2 just to save space until we get our new building up and I can do a more permanent build. I think you'll find it flows well.
Policar track
Discussion Starter · #20 ·
I'm toying with the idea of changing the table layout from 4 x 16.
to a L shape layout.
1 - 20 of 29 Posts
