Hello! I was one of the early adopters of Digital, back when ProX first came out. I built a massive single lane Pro-X layout, but the tech wasn't exactly ready for prime time. I eventually built a 4-lane Carrera monster analog track but took it down and sold everything when I moved.
I was trying to recapture some nostalgia, and was going to buy a 4-lane AFX Super International track, but then I saw that Carrera has updated their digital system. I can't fit a "club" sized track, but there is a nook that I could either fit a 4-lane HO track or set up Carrera Digital on the floor.
(Incidentally, I got pretty deep into digital. 2005? 2006? When N-digital came out, I retrofitted it to work with Carrera track and lane changers. I also figured out a way to quadruple (quintuple, etc) the power so there was no power drop with 8 cars. It was similar to how they would parallel Scalectric Digital power bases, except I was buying the chips from Mouser. Unfortunately, Ninco Digital had its own problems and appears to be dead these days...)
Anyway, I had some questions about the new D132/124 and Carrera in general.
1) Frankly, the reason I returned to analog was because the driving experience was much better. ProX was "pretty good", especially with chipped Fly Cars, but Carrera cars were slow tanks with tall gear ratios and strong magnets. Are Carrera cars any better in 2020? Are they still slow tanks?
2) When analog cars are chipped to D132, is the driving experience just as good as analog? Full acceleration and braking, throttle control, etc. I read there is only 4-bit, 16 levels of control. I don't remember it being a problem with ProX, while the same could not be said of the Ninco system. (ProX worked pretty well, but it would have been better if you could adjust the voltage curve so the decoders worked well with every motor and gear ratio.)
3) How many amps (how much motor) can the decoders handle? The system is designed to run 1:24 cars, so I figure with the right decoder, you can build a really quick 1:32 car.
4) Does regulated power supply solve the problem of voltage drop with the standard CU? When you have six cars on the track, can you "feel" the other cars? With Ninco Digital, the control units would need to be paralleled in order to avoid voltage drop. I don't remember all the details.
Trying to decide if I should buy the AFX Super International set, or get a Carrera Digital set to scratch the itch.
