321 - 340 of 450 Posts
We are using value 2 for combustion and it suits us perfectly for the 55m rope track. The tank takes 60 laps to spend at 13.8 per lap on average. I understand that if we put value 3, consumption will be half of value 2 ???
To delete a wrong lap, how can I do it ???
Discussion Starter · #322 ·
The burn rate is a multiplier, if you make it 3 it will burn faster. If 2 suits you leave it like that, fine tuning if desired by changing tank size.
Deleting of laps is not possible, sorry. Next release, but not so easy as it sounds.
Computer Computer monitor Television Gadget Flat panel display
Rectangle Font Parallel Technology Wood
After yesterday's 6-hour race, in the end we were 6 teams. We use Scp3,2 and 1, also chips B, B1, B2 and C1 all this with different fireware. Dongle version 3.10. The race was contested with gasoline consumption. Everything worked correctly at all times, until after 2:30 hours the program began to slow down. He counted the laps and times well, but when it was time to enter the pit lane to fill gasoline, we pressed the round button and he ignored it, the order to fill gasoline came very late. I think it may be because of the pc that will collapse due to the reception of a lot of data, but it can also be due to the large amount of data that the dongle does not support ??. I doubt that it is the latter, I think it is the club's pc. For everything else everything is correct. I want to add that we cloned the SCPs of each team, we took advantage of the pilot changes to fill gasoline, when we changed the pilot and change of command the team screen disappeared and reappeared, but to continue the refueling it had to leave the pit lane and re-enter. It would be great if the screen did not disappear and continue to refuel even if the SCP is removed. Thank you very much and I hope it helps
Discussion Starter · #324 ·
Thank you for this report! I suspect the PC too but I let Martin check this. We have done events that last also 6 hours but not with 6 cars. However, there is not much data stored so I doubt it is the software. We also have sometimes that the brake button did not respond but this does not happen anymore, not sure what fixed it, a dongle or controller fw update probably. You know you can refuel to 100% with marshall screen too?
· ParrotGod
I did not know that you can change the fuel from the marshal screen. Will use in the future ;-)
We have the issue with the brake button not working. Usually this happens at the beginning of a race when all the teams have to press the brake button to select "ready".
Usually resetting the power to the controller would solve the issue but when the race starts then the team screen is not present.
This requires another controller power reset during race. We usually do this when a track call is called: the driver resets the power of their controller and the team screen reappears (this still under track call). However, when the controller is reset then the first lap is not counted: to avoid loosing a lap, we manually push the corresponding car over the S/F line. Depending how quickly you do this, you might need to add damage points as well (using the marshal screen).
Before we went into the last lockdown I think I have discovered that if you press the throttle several times then the brake button works again...but I will need to confirm this under racing conditions.
Discussion Starter · #326 ·
For those that missed our update on FB a while ago, we are now developing a mobile app for RCSO2 ourselves (difficult,frustrating sometimes, but also fun), as this is new for us it takes some time, but we have some progress and are in the final stages of this project. Once we have it running we will continue our work on the new and improved RCSO2 so that we can release it together with mobile app support. Yes, takes longer than we hoped, but as always once we release, it will be good :)
Martin is doing also some important work in the background that will improve the stability and reliabilty of the overall oXigen system. So all in all, lots of work, less promotion, just trust us it will be good.
Tire Vehicle Automotive tire Motor vehicle Automotive design
For knowledge and timely effects in relation to this thread. The Costablanca club from Alicante (Spain), again performs a 6-hour resistance with RCSO2, we will pass all the possible information about the software. You have all the information about the race in the events thread of this forum.
Discussion Starter · #334 ·
Super Fer! Yes please share the info, we might be able to use your input for the bew RCSO2.
No launch plan sorry, because we do this as hobby and the past has shown is that giving end dates often result in dissapointment when we can't make it. But you can be sure we are working on the new RCS, app reaches its final stages so we are already busy with the structure of the the new RCSO2.
