1 - 5 of 5 Posts
I recently got a cable for my C7042 to connect to a laptop and I have upgraded the firmware to 1.06, without any problems.
Now I'm having a go with the SSDC software, everything seams fine apart from refuelling. When I stop either in my pit (not pit pro) or just on the track and press the lane change button the fuel level doesn't go up. Does anyone have any ideas what I am doing wrong?
Lane changing works, the refuel after x seconds is set to 0.5, I've tried with two different cars and two different drivers.
Any help would be much appreciated!
Ade
Did you make sure that you've checked the pit setting to one of the "No sensor" options? It might be set to one of the Pit-Pro options, which means it's waiting for a pit-in indication before it lets you fuel up.
The option you're looking for is found at the top just below the normal menu stuff, and I believe is one of the checkered flag icons.
1 - 5 of 5 Posts
