QUOTE (stoner @ 27 Apr 2012, 02:25)
<{POST_SNAPBACK}>that wasn,t the question rick take a 14t pinion 9mm in dia and mate it to a 42 gear 3-1 then take a 6t pinion 5mm in dia and mate it to an 18t gear. whats the advantage, does a big pinion drop motor torque or does a small pinion increase motor torque.pretend that wheel, ground clearance isnt an issue. why would you go for the different pinions and gears to achieve the same ratio 3-1. there must be a very good reason judging by the racers and scratch builders setups. i hope this is a bit clearer. john
But you sked two questions, and Rick answered both in really simple language.
Q1 would some one like to explain the different combo,s, and why. take a 3-1 ratio, the standard is 9-27. going to extremes, what about 7-21 or 11-33 there must be a difference and i,d like to know.
A1 one of the questions youre asking is whether there is for example, a difference between a 6.5mm 9T pinion coupled to a 19mm 27T spur compared to say a 5.5mm 9T pinion coupled to a 18mm 27T spur. On the assumption that they mesh properly then both MUST provide the same mechanical advantage which will be 3. The leverage as you call it will be the same in both cases, and that is 3.
Q2 a euro sport runs 6-1 6-36 why.
A2 why a particular ratio and not another? That really depends on the torque of the motor, the rpm, the wheel diameter, weight of car, is top speed important or is acceleration, short track, long track etc. You choose a ratio that gives the best performance for your situation. Sometimes its as simple as the physical room you have that dictates the gear sizes used.
Why make a 16T pinion? Well the motor may be a low RPM type with huge torque, so you can afford to go to a 16T with say a 36T spur. Put that in a Scaly motor with about 90-100 g.cm of torque and the car will be very sluggish.
What amazes me, is that this same question comes up here and on other forums quite often..... I guess a lot of folk have trouble getting their heads around there being "
several methods of removing the pelt from the moggie"
Gearing ratio is gearing ratio, it is a multiplier (or reducer) of force as required to acheive the objective - just the same principle and kids on a see saw (teeter totter for the americans), light kid, use longer side out from the hinge-point to equal heavier kid closer to the centre. - That explains why choose different gearing ratios..... Q2
The only thing to add would be that since most of our gears in RTR racing are based on approximate 48 pitch, give-or-take a smidgeon, different tooth number combinations are needed to get the physical "fit" in the cars for the different motor arrangements. - inline, anglewinder, sidewinder.
ie
- for low to ground anglewinder cars you may be using say 8:24 in gears because that is what for instance Slot.it make to fit for the low GT/LMP cars,
- while an inline may be 9:27,
- and a sidewinder setup with 6.5mm pinion may be 12:36, simply because you need to use such 6.5mm and 18 or 19mm diameter spur gear sizes/diameters to make space for the motor and axle shafts to physically fit alongside each other.
