I'm going through my old cars trying to fix them and noticed some have lighting out of action. Some such as my Renault Megans, & Legunas
have plug in and twist bayonet plastic fittings with a wire leaded bulb fitted about 5mm thick. Do any of you know what spec this bulb is?How many watts / voltage size / code etc? Scalextric only seem to sell the whole lot as a unit with the plastic holder I don't need?
In another Porsche 911 I've found a single tiny centrally mounted bulb in a plastic rail to light the front headlights. This appears to bealso a wire lead bulb but much smaller in dimensions? This car has the little printed circuit board with 2 capacitors in it and includes 2 rear LED's I think? Would this front bulb be a lower voltage than 12V?? Mines failed and so prevent the rear circuit working too.
Again what spec? Grain of rice?? Some cars seem to have 2 separate bulbs for headlights too so would they be different again?
I thought if I can get the bulb sizes, voltage and specs I could try Maplins or RS online for replacements.
Would another option be to replace both types with LED's or would that not work without further mods?
Thanks in advance
H
Thanks in advance
H
