MGB 1964 Monte Carlo Rally
BMC Works car, No. 83, Reg. 7 DBL
Reference: C3143
Type: Single car, crystal box
Class: Classic
Availability: May 2011
For many, the MGB is a long awaited addition to the Scalextric range. Not before produced by Scalextric, this famous, iconic and most British of all sports cars is proudly introduced to the classic range in the livery of the famous 1964 Monte Carlo winner of the GT class. The detailed car includes wire wheels with knock-off spinners, working lights at the front and rear as well as magnatraction and Scalextric Digital compatibility with DPR.
History: 1964 Monte Carlo Winner and Britain's best-selling sports car of the time. 7 DBL is an immortal number plate to MGB aficionados because it was driven to victory in the GT Category for sports cars and 17th overall, on the 1964 Monte Carlo Rally by Suffolk based farmers, twins Donald and Erle Morley. They started the event from Oslo and the final result was remarkable for an 1800cc car, producing approximately 125bhp. Previously, when fitted with a streamlined nose and aluminium panels, 7 DBL had won its class in the 1963 Le Mans, driven by Paddy Hopkirk and Alan Hutcheson. '7 DBL' had been used extensively in endurance and rally events worldwide with sister works cars '6 DBL' and '8 DBL'.
Features: High detail. Magnatraction. Quick-change guide braid. Working lights front and rear, Magnatraction. DPR.
Configuration
Motor
Mabuchi FF
15k rpm @ 12v
Gear ratio 9:27
Chassis
Rear Mounted Motor
In-Line
Rear two-wheel drive
Magnet
Rectangular 2 mm
Down-force 198 gm
Overall length
120 mm
Wheelbase
72 mm
Axle/Hub width
45 mm Front
44 mm Rear
Tyre diameter
19(ext), 12(int), 5 mm Front
19(ext), 12(int), 5 mm Rear
Weights
Car 70 gm
Case 156gm
Scale = 1/32
