1 - 4 of 4 Posts
I read in a forum earlier today that some cars will quit registering laps or with pit pro after being scratched up a bit, but will still register with the LC's. Is this a big issue with the LED's getting scratched. Several of mine are scratched and I notice that sometimes my LED's will bump or drag a bit. Thanks for your help!
Matt
Hi Matt
I'm assuming you are referring to chips you've installed yourself, I've not had the same issue as you with the LEDs not registering, however on installing the F1 or Saloon chip I have installed the LEDs too low sometimes and I don't reckon it was a good way so I've always just lifted them up a fraction and it's made no difference to them registering but no dragging.
A friend of mine suggested using the little spacer you get in the Scaley box that sits between the box and the car as a spacer for the LED to sit in, this works a treat and with a dob of hot glue you can get it exactly where you need it.
Marty
1 - 4 of 4 Posts
