1 - 2 of 2 Posts
If I were to use the pit box with copper tape connected to it so that the electricity flows would it work?
Also what is the maximum angle a car can climb/fall and what would be the best way to connect the slopes to the track
Yes it should but I would also solder wire taps between the copper and rails.Also if you plan on routing lane changes
you have to solder in capacitors wherever there is a break in the copper.I know this because I burned out a
control board($90)
here is a photo of a stock lane change showing the capacitor,it has 309 printed on it,I could not find any for sale separately
so I cannibalized them off of track pieces.
Hope this helps you a little....
1 - 2 of 2 Posts
